Has any one had problems with there clutch master cylinder going out because of an aftermarket clutch kit? The thr aftermarket clutch is alot harder to push down and the seals in the clutch master cylinder cant take it. Has anyone had these problems?
Clutch Master cylinder Problems
Originally posted by 93F22A6 View PostMight want to replace it. Could just be the age of it.
Originally posted by 93F22A6 View PostWhat clutch did you get again? Could have installed it wrong, i'm not sure just a guess.
I just change my master clutch cylinder, and that fixed it.
BUt the Q's was had anyone worn out the master clutch cylinder in a quick time using and aggressive clutch kit, I have the ACT HA3-Xtss clutch kit. The one that holds 395 ft-lb of torque
