H22A4 swap help
    H22A4 swap help
    I have a friend who is going to sell me an H22A4 for $350 the head is together but the whole bottom end is taken apart and clean but all it has is the block, flywheel, pistons, rods, balance shafts. how hard would it so swap into my cb?
    I have an F22A6 if it helps any, would i be able to you my intake and headers?
      it wont b hard to do the swap. i thought it would b hard to do but it wasnt. as long as u take everything off and out u are good to go. also u can use the intake. but not ur header u have to get a header for a obd1 prelude. i think 92-96 it has to b the V-tec one.
        get an obd1 h22 dizzy and injectors and gett an p13 ecu wire vtec knock sensor and vtec oil pressure is it a base motor or a sh motor? cause it its a sh motor u have to make a plate to bolt the half shaft to the back of the motor. use ur f22 mounts and axles
        h22a4+p2u5 trans+8000rpm= 135mph in 4 gear
          i got my header off the 2000 prelude i got the motor out of i just had the lenghthen the o2 sensor wire but if ur car is ex u want have to
            my car is an ex so its already down there i was just iffy on if it would be worth is.
              i say do it i love my motor i had a lil trouble with mine at first but the more i read about it on this site i found my problems quick man if u need any help just pm me i will help u.
                thanks hope i can have it put back togather and put in with in the next coulpe of months
                  so possible just take ur time put it back together i have learn never rush puttin a motor together mess up my schools chevy 350 trying to rush
                    i plan to take my time and do it right i was just kinda excited about an H22 in the cb until i found how much it doesnt have with it.
