external to Internal coil
    so i looked and cant find anything on changing to internal coil...
    reason being i just got a f22b (thanks darkcloud) and i recently sold my ext coil and dont want to buy another one so can this be done? what do i need?
    i think i have this covered.... i have extra internals from a ext coil dizzy im just gonna swap the stuff hope it works
      http://www.cb7tuner.com/vbb/showthread.php?t=5423
      Internal/External Coil Issues:
      If your car came equipped with an internal coil then the JDM H22 distributor will plug right in no problem. However, if your car had external coil then you will have to modify one plug. The plug you will need to modify is the plug that went to the stock coil. There are is a yellow and a yellow/black wire, splice those 2 wires together. The Black/White wire is useless, don’t worry about it. If you dont want to cut the plug off and splice, jam a 30amp fuse into the end of the plug, making the connection between the two wires.
      If your car is external coil and you wish to maintain the external coil you will need to open the JDM dizzy, remove the internal coil. Run the wire from the igniter that used to go to the internal coil out of the distributor and plug it into the blank spot on the distributor’s plug. That’s it. Use the 93-95 Prelude Vtec’s Distributor cap and rotor that you can pick-up and your local dealer or auto parts.
