Hey everyone, I just finished my h22a1 swap, used my 92 accord wiring harness wired up everything correctly, now it won't start... It turns over and wants to but won't, I changed the distributor, and am now out of ideas. Please help this is my main transportation!!!
h22 swap not starting
Originally posted by BrokenAccord View PostHey everyone, I just finished my h22a1 swap, used my 92 accord wiring harness wired up everything correctly, now it won't start... It turns over and wants to but won't, I changed the distributor, and am now out of ideas. Please help this is my main transportation!!!
Originally posted by BrokenAccord View Postare these things that are easy to find, sorry, this is really frustrating to me. Where and what is the ring terminal??
Look at the themostat housing... Low on the housing ...If there is no wiring on the ten mm bolt then it is not going to start/ run right... The harness is only go long so look around...
A ring terminal is a terminal that looks like a ring...
Dizzy
You mentioned that you switched the dizzy.
Did switch internal / external distributer?
If so this could be your problem. There is help in the swap guide about what to do if you did do this. It just requires a fuse shoved into a connection.
If you don't know what you did dizzy wise. Find out what distributer you were running before the swap, and what one you put in.
Regards.
Originally posted by Ghetto_CB7 View PostYou mentioned that you switched the dizzy.
Regards.
Ghetto, thanks for that, I know I have an external coil dizzy and I do have the external coil.
I am really stumped and need to get this car running
any CEL
First of all I need to ask if you have any CEL's
Also how many wires are on this plug, what color, and where does the plug come from wiring harness wise. I cannot think of any wires that come from the lower timing cover.
Only ones near there are knock sensor, oil pressure sensor, and a pressure sensor for power steering.
