I found a H22 for for a really good price that needs rebuilding. The problem with is that is has a spun bearing.... What i wanna know is whats invloved in fixing this?? What would something like this cost me to fix the right way??
H22 w/ spun bearing question....
What's involved is pulling the motor apart taking the crank and rods out inspect all bearings replace bearings.Originally posted by I<3mycb7 View PostI found a H22 for for a really good price that needs rebuilding. The problem with is that is has a spun bearing.... What i wanna know is whats invloved in fixing this?? What would something like this cost me to fix the right way??
DIY would be cheaper if you plan to rebuild the motor from the ground up
headgasket
waterpump
timing belt
balancer belt
tensioner's
Cam,crank and rear main seals
Valve cover gasket kit
exhaust and IM gaskets
etc. Lets say thats 400 in parts and doing it yourself
Depending where you live part price's vary
A shop price range could be 550-1500
I just had the same problem. For me the whole bottom end was trash, I spun one main bearing and all four rod bearings.
If you spin a main the block and crank is trash, if you spin just a rod then the rod and crank will be trash.1990 accord Honda-Challenge, H22 powered
newer race video,older race videos
1991 accord parked, parts and back up shell
1993 accord acquired 6-11-16
