ok i got a 92 honda accord
i swapped a h22a of course.
i used my stock wiring harness and i followed all the wiring diagrams to switch is over such asd the knock sensor,the vtec wiring and such.
i hooked it all up and put the battery in and it wont turn over at all
im getting fuel and im getting power to the starter cuz i took a mutimeter to it.
the main relay was humming at first which would indicate a gound problem. i looked around and found that i didnt have the thermostat housing ground on. so i bolted that on and it still doesnt start.
im not sure what it could be. im not a mechanic at all im just a body man
so basically at this point i turn the key and i just hear the main relay click
but it sounds different then how it usually would sound.
Im not sure if the starter is getting what it should.
is there any tests i can do that will tell me if i got something hooked up wrong or sumthing
also at the block theres the bracket that ahs the ground from the battery. theres another hole there and im not sure what goes there.
if anyone has any idea's i would be very thankfull
