okay, so i found a pretty good deal with the friend of a friend, and i'm going to be getting a manual transmission with clutch and flywheel, slave cylinder, shifter cables, and 2 shifters (one short one regular, which i'll probly sell the short shifter.) all for 150 bucks. i'm thinkin it's a pretty good deal. but, i'm going to have to get new motor mounts, which is okay because mine were going to be replaced anyway, even if i stuck with auto. so, my question is, is there a specific brand, type or size or anything like that i need to look for when i go buy some?
motor mount help
i'm considering something like this:
http://cgi.ebay.com/ebaymotors/Honda...ht_2022wt_1165
but i want to make sure it will line up with my H23A1 also.
just warning you, I've got the ESP Auto to 5spd kit and it does transmit quite a bit of vibrations if you use your car for DD duty. When the AC is on, its kinda annoying at stoplights w/ the wheel all shaking and vibrating. But I guess its a tradeoff, for direct power to the ground with no slop compared to OE mounts and little to no engine movement when shifting so you can easily powershift w/ no worries.
I eventually went with some Billet Aluminum Hasport mounts since they're local and the durometer of the poly is slightly softer, 62a vs 70a urethane. I'm still waiting on them to make an Auto to 5spd mount for my H22 CB though....its been like 4 months since I left my car with them to take measurements for that mount and no word back since then.
They do have the Engine and Rear mount available right now though.
member's ride thread
91 Accord SE 176k
well my car is still gonna be my dd, but i'm deleting AC (doesn't work anyways), and my car already shakes when idling too. plus my 'reverse' just went out yesterday, so i really need to get this thing going.Originally posted by Losiracer2 View Postjust warning you, I've got the ESP Auto to 5spd kit and it does transmit quite a bit of vibrations if you use your car for DD duty. When the AC is on, its kinda annoying at stoplights w/ the wheel all shaking and vibrating. But I guess its a tradeoff, for direct power to the ground with no slop compared to OE mounts and little to no engine movement when shifting so you can easily powershift w/ no worries.
