did a f22b1 swap in my accord and im having issues with my fuel rail i read the swap info on the thread and it didnt have a good description on how he flipped the fuel line and regulator around can anyone help me or tell me what i can do to solve my problem
f22b1 fuel rail issue
I dont think you would want to flip the regulator. you probably would just want to extend all the lines to the rail. I own a cd5 and I studied on doing the f22a1 head swap so its like the exact opposite. you can buy some fuel line from your local store and just cut out the old, meaure cut and use lots of clamps, nice and tight. should work just fine
i just did a f22b2 swap in my 93 ex sedan, you have to lengthen the fuel line its time consuming try to flip everything around. like he said clamp it up nice and tight, thats what i did. if u had the a6 in before the b1 be sure to do ur homework on the sensors such as the map. i still cant find a map plug for mine anywere on th harness.i wouldnt recomend either motor as a swap canidate. but it was cheap an quick so i used1.
