ok help
This topic is closed.
    ok help
    I'm in a spot where I don't now what to do. My car has an attitude. I'm wondering if there is anyone in PA-NJ between trenton philly and bensalem who's swapped that I could hook up woth and look over my car. Here are the issues-
    Cold start- screwed up idle... give it gas it sputters. Tried to resolve by swapping:egr, iac, and fitv.
    Cold idle does not idle high
    Warm idle: idle at 750. Drops to about 400-450rpms every 30 seconds. Tried to resolve as above.
    Every once in a while when I go to start it up I hear what sounds like a spark and loose all power. I wait a while like 20-45 minutes and it starts.
    What I'm thinking is the idle issue is due to fpr that I didn't swap with the preludes. So I'm using the accorx fuel pressure regulator. For the loss of power I must not have something grounded right. That can also affect the idle though right?
    IridiumCore
    HCK-The Beginning
    Your drunk she doesn't look that good.
    first of all bro, you didnt get any responses because of your title were guessing you didnt read the rules/tips to get better responses.
    and sorry i cant help with your problem, but just giving you a tip on how you should post better threads.
    AT WEST COAST MEET
    cb7rush: who has the tongs?
    JDMxDB8: i got a thong on...
    to get to see more of my cb click the link below.
    http://www.cb7tuner.com/vbb/showthread.php?t=130922
