Did a jdm h22a swap in my 90 dx.
Using a jdm p13.
used f22a1 wire harness, only extended, temp sensor wires.
Answer 1 or all pleas and thank you
1) First question is
What are the specs with the throttle position sensor? ohm volts.
(im using specs close to f22 specs)
also when testing the TPS wire coming from the harness, you are suppose to get a voltage from the outer wires, i get no voltage
the green and white wire (ground) has continuity to the negative terminal.
and then i used a volt meter to the yellow and white wire (voltage feed) and and to the POSITIVE and i get a voltage
is that normal? car runs fine, needs a slight adjustment thoe.. any ideas?
2) i have a CEL for o2 heater code 41, no cut wires, and i checked ohms and voltage on all connections and everythings ok even bought a new NTK sensor today, and still have the o2 code.. i tried other ways to bypass, cant get rid of code,
im not getting a p28 till nxt spring, i want to get hondata, but i rather have a motor running without any cels for now.
any ideas or comments id appreciate it. if you dont understand my problems just ask. thanks
Using a jdm p13.
