Hello. I have a problem with: check engine light circuit.
I have a p13 ecu installed ended on h22 swap.
The problem is that I do not get the CEL to start the vehicle.
Again I install PT3 ECU, if you turn on the check engine light on the dash.
with this discard BULB.
I can do to get the CEL?
If you power the vehicle works.
Thanks for your help
