i have a fully built bottom end f22a and the head and intake is an h23 non vtec, i took some pictures of the vac. line coming out of the black box where the map sensor is at, when ever i hook up the vac. line it idles up to like 5k, so when it starts to do that i just shut the car off so nothing bad happens, i also took some pictures of random plugs on the wiring harness that are not connected. im running hondata s300, and when the vac. line is off the computer says the map is reading -.02 and when connected it is reading -15 ish which i beleive is normal. any input on this would be helpful thanks.
i beleive the 2nd picture is a coolant sensor, the f22 front water neck i had, had the sensor on it and the h23 one does not, im going to swap it out for an f22 one
