M2b4 swap question
So I did not get the clutch, flywheel, or pressure plate with the tranny. Do I need to get h22 parts or can I use f22 parts?
Leave a comment:
^correct, stock f/w is the same as an H22 f/w. You're going to love that setup, M2B4 really woke up my old F22A6! Go easy on the 5th gear though, no speed-shifting!
Leave a comment:
Thank you both for that. I was curious as to whether the clutch and pressure plate will work than?
Leave a comment:
yes, it's a direct swap. but you have to relocate the studs where the transmission mount goes. and use your Accord intermediate shaft.
Leave a comment:
M2b4 swap question
I have found a deal on a nice m2b4 tranny with all the fixings. My question is can this transmission be bolted onto my f22a1 motor or do I need to reconsider?Tags: None
Leave a comment:
