Just thought Id lay out my ramblings in my head out here since it might be of use to some people.
Prelude gearbox M2A4
(1)3.307 (2)1.950 (3)1.360 (4)1.034 (5)0.787 DR 4.266
Stock steelie tyre size 185 70 14 = (1)38 (2)65 (3)93 (4)122 (5)160 mph @ 7500rpm
Current alloy tyre size 215 45 17 = (1)39 (2)66 (3)95 (4)124 (5)163 mph @ 7500rpm
Trackday alloy tyre size 225 45 17 = (1)39 (2)67 (3)96 (4)126 (5)166 mph @ 7500rpm
To get 2nd down to 60mph
Short ratio tyre size 205 45 15 = (1)35 (2)60 (3)86 (4)113 (5)148 mph @ 7500rpm
Ride height drop of 60mm (2.3") Not fisable unless raising suspension to stock height.
Accord Type R Gear box U2Q7
(1)3.285 (2)2.090 (3)1.481 (4)1.071 (5)0.870 DR 4.266
Stock steelie tyre size 185 70 14 = (1)38 (2)60 (3)85 (4)118 (5)145 mph @ 7500rpm
Current alloy tyre size 215 45 17 = (1)39 (2)61 (3)87 (4)120 (5)148 mph @ 7500rpm
Trackday alloy tyre size 225 45 17 = (1)40 (2)62 (3)88 (4)122 (5)150 mph @ 7500rpm
Prelude Gearbox vs Accord Type R Gearbox
Prelude trackday alloy tyre size 225 45 17 = (1)39 (2)67 (3)96 (4)126 (5)166 mph @ 7500rpm
Accord trackday alloy tyre size. 225 45 17 = (1)40 (2)62 (3)88 (4)122 (5)150 mph @ 7500rpm
Conclusion
Prelude box is too long to simply shorten slightly by dropping tyre size for track use.
Accord Type R box has a much better set of ratios for the track but 5th gear for daily driving is 54mph @3000rpm compared to 60mph @3000rpm for the Prelude.
Since the Accord F Series 5th gear swap would be too long of a gap for the Accord Type R 4th gear, a compromise maybe is using the Prelude 5th gear in the Accord Type R box.
Reality for now
I will probably just use an Accord Type R gearbox and not bother with the 5th gear swap, I could pull some fuel useage out of the 3000-3500rpm map range and fuel prices are cheaper currently. So saving is not worth the effort.
Conclusion
Reality for now
