Is it possible to replace this sensor, or do i have to buy a whole new throttle body (which i dont wanna do)? I noticed there are no bolts or nuts holding it on.
yah bro just drill out those rivots, and get a new one from the junk yard, if my memory serves me.
alright, ill try that, but cant i just use the one off my accord engine?
yeah they are swappable between all of the F and H motors.. just some of them have break-off bolts holding them in that dont have a head on them. youll need to grind off the rest of the head that you see and pull the sensor off and use vice grips to pull the rest of the shaft out of the throttle body... then find two REGULAR screws that will fit... so you can use a regular screwdriver in the future...
just for the record. Any 88-200? honda or acura tps will work. only difference is some have a diff clip setup. search through some older threads (DIY forum i think) and youll find an article about setting the tps to the propper voltage. THIS IS REQUIRED WHEN SWAPPING OUT TPS
