i'm having a serious problem on my motor swap. I really need some serious help and No one seems to have a real solution to my problem.
I have swapped a H22 motor into my 93 accord EX auto. I went from manual to auto conversion and H22 swap all on one shot.
Here are my issure if you can help I would really be thankful.
EGR valve. The H22 EGR valve is not the same as the Accord and will not plug into the accord, anyone know what the deal is with the wires I'm going chop the plug and wire it in the H22 plug.
PS pump.
What pump and what line?
I see some peopl with H22 pump and some with Accord pump.
Whats the deal.
Crank pulley, did anyone have an issues with the H22 crank pulley not having clearance to the frame.
If you swap on the accord pulley what did you do with the power steering?
And PS pump bracket?
Also, What to do with the external to internal coil issue.
My H22 motor has an internal coil, Do I need to some kind of wiring?
Which Throttle cable and can I keep the cruise control if I use a some kind of H22 throttle body or some how swap in the correct throttle wheel.
Please help me the car has been out for a month and no one seem to know of have any of my issues Everyone say is all drops righ in and no problems.
Thanks
Andy
PS pump.
Whats the deal.
Thanks
Andy
