I need help. what do I have to do to get ac back in my car? what lines do u have to use and what compressor? right now i believe i have the prelude compessor in there.
Some Help Please IM hot!!!
when doing h22 swaps you dont touch the ac. all accord lines, compressor, condensor, etc etc etc. even the bracket that bolts the compressor to the motor
ditto. Stick w/ all accord stuff for a/c like everyone else says. I just finished my swap a few weeks ago. Of course, I opened up the system & I need to get the freon charged but definitely stick with all accord stuff.
Keep in mind that you should also use the accord crank pulley (4 ribs as opposed to the H22's 5 ribs). That way the belts you use will be accord.
*Note: don't forget to use the accord p/s pump & bracket (if your going to retain p/s). The H22 one will sit differently & belts will be different because of the accord crank pulley.
I think I retained all the Prelude pullies... I'm pretty sure my shop made a custom PS line, and the AC needs a custom line as well according to them. I'm about to use the Accord stuff with the Prelude pulley... I just need to DO it!
swap in an accord compressor and lines and use an accord belt and itll fit mike
so, i have a JDM H22 (with alternator, power steering pump and crank pulley from H22)... wouldnt I use the H22 compressor to keep the belts all H22? Could I use the F22 bracket with the H22 A/C compressor?
If you use the H22 compressor you will have to get custom a/c lines. Prelude lines and accord lines are different. So is the compressor.
Use the F22A compressor with the F22A bracket and belt. The crank pulley will have an extra rib left over but thats not a problem when the belt is properly tensioned.
Or just use the F22A crank pulley on the h22 and have everything match up.
i used the H22 compressor, both ac lines ( suction and discharge ) were custom made, basically an accord fitting on one end and the h22 fitting on the other.
the only thing that was difficult was finding someone braze the two ac adapters.
