Ecu or Tranny Problem?
    i have a 92 accord and every time i put the gas to the floor it red lines unless to come up off the gas a little it is an automatic by the way. just say if i was going to racing someone and as sooon as i come off the line i floor the accelerater i will red line everytime unless i come up off the gas.
    that makes no sense
      Shift out of park.
          so lemme get this right with my deciphering skills:
          if you're going to race someone and when you TRY to come off the line by flooring the accelerator, it redlines on your tach but nothing happens; and only then if you let go of the gas pedal, then it goes.
          i think you're auto-tranny is failing or just about to go
          5.6L V8 32V DOHC
          JDM HERITAGE - US BUILT
            word to primo...its the tranny..either that
            or you need a new hobby
              Yes, your auto tranny has a combo of burned clutches and a worn piston if its doing that.
                I can take off but if i dont get off the gas ill blow the engine because the tranny never change gears unless i ezz off the gas
