F22B DOHC won't start
    please scroll down i got a question about interna to external coil
    Well guys, i finally hooked everything up on my f22b.I put a 30 amp fuse on the ext. coil plug and i tested it with a test light and it lights up so thats out.i get fuel in the fuel rail, but when i pulled the plugs out only cyl. 1 and 4 smell like gas.I cranked it with out the plugs and fuel shot out.I think i have no spark, but how do i check if i get spark on all plugs?Also, it threw a tps code, but i pulled it out and put in agian, disconneted the battery,waited 30 secs and it never threw the code again.I didnt expected it to start right up so i'm not having second thoghts about the swap yet, but i'm pretty sure you guys can give me more stuff to check on cuz i'm to excited now and i have to clear my mind.
    P.S.-sorry for the confusing post, i'm in a hurry
    ILBB
    People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
    Mk3 Supra Member #2
    Originally posted by DarkShadow707
    The world needs to be reset.
    first off, what year is your car (ill make things easier) second lets say when you did the spark plugs wires you did everything back words like 1 on 2 3 on 4, or 4 on 2 or 3 on 1 (you know what i mean) take out the spark plug wire out from the spark plug and let somebody crank it, while you hold the end of the wire to metal if it spark then you have spark and if not you may have a bad coil or a ignitor. ignitors usually go bad. check all your fuses, grounds, and so forth
      thanx, the car is a 93 ex.heres how i did my spark plug wires:
      2-4
      1-3
      I think i got bad injectors.any other input is apreciated.
      ILBB
      Mk3 Supra Member #2
        also, i grouded the transmission ground, the ecu groud under the thermo housing, the ground on the valve cover, and the one on the ps pump,am i missing any?
        ILBB
        Mk3 Supra Member #2
          Sounds like you got them all to me.
            i think i figured it out.I am getting no sprk at all.I'll try to convert to ext. coil tommorow.Whats an ignitor and how hard is it to repalce?
            ILBB
            Mk3 Supra Member #2
              bump for some info guys!!!Is there anyway i can check if the coil is bad?i took it out and it looks good, i dont know what to look for.i doesnt seem burnt or anything.
              ILBB
              Mk3 Supra Member #2
                I can only tell from how the car is running. Its pretty hard for me to tell what a bad internal coil looks like on a Honda. I just went external with my MSD.
                  ok, i wnet to advance auto and asked for h23 internal coil and they said there is no such thing.What internal coil will fit in my f22b dohc dizzy?plz help,i'm getting all paranoid about me not being able to start my shit and i just got my liscence and i cant fucking drive!!!
                  ILBB
                  Mk3 Supra Member #2
                    Arent there only like 2 coils made for the internal dizzys? Also auto stores are idiots. If you have a chuck of change lying around, MSD all the way.
                      ILBB
                      shit i didnt ground the thermo houseing on my swap pics please so i know were it is
                      www.2camcrew.com
                        ILBB
                        usdm h23's use external coils that's why they say there's no such thing. I want to say the ignitor from a 99/2000 civic si works but can't say for sure.
                        Post count is not = to experience rating
                        F22B DOHC
                          does your car start?if it does dont worry about it.Just see if you connected it under the thrmostat housing.
                          ILBB
                          Mk3 Supra Member #2
                            ok guys i know what wires to extend from insid ethe dizzy but were should i connecte them?i searched but all the write ups are with msd setups i'm just using my stock a6 coil.so do i connect them were the plug should go and stick a 30 ampo fuse?help im confused
                            ILBB
                            Mk3 Supra Member #2
                              Dude you are having the same problem I did. I ran the wires out too and used my stock ext. coil and it fired right up. Just look at your old dizzy (assuming it has the same wiring as an H23 dizzy, don't know, I used a spare broken H23 dizzy for mine) and open it up and mimic the wiring, thats what I did. It was a while ago but I definitely remember that I only had to run one wire out of the F22b dizzy throught the rubber piece to the the cannon plug. (If you notice on the F22b plug there is an empty slot. Your stock dizzy has all the wiring on its plug. Check it out. Took me about half an hour and I haven't had a problem since.
                              JDM F22B DOHC
