How difficult is it to wire up the MAP sensor on the throttle body? I can't find a firewall mounted MAP sensor for a decent amount of money so I'm thinking about doing this instead because it's cheaper. By the way I have a JDM H22 swap.
Bad MAP sensor question?
Before you go gettin' yourself all fuckin' stressed out, it's alot easier than you think. I ended up having to use a TB that had no provision for my original TB-mounted MAP sensor... so I just popped it off and stuck a hose on the nipple underneath the sensor. If for some reason you need to do custom wiring, there are only 3 wires dude... grab a book and go at it.Last edited by Dirty Harry; 11-16-2005, 05:49 PM.
jdm h22a swap
well when you do the swap into a 90-93 accord what do you do with the map sensor my engine did not come with one. i know my stock one is in that black box above the evap canister. all i did was hook the vacume line that ran from the map sensor in that box to the nipple on the throttle body. is that what i was suppose to do for the map sensor. i mean everything i read about the swap is that you mount to map sensor on the firewall. im very confused! someone help me out
no need to be confused.. your setup is fine.Originally posted by RidnLowwell when you do the swap into a 90-93 accord what do you do with the map sensor my engine did not come with one. i know my stock one is in that black box above the evap canister. all i did was hook the vacume line that ran from the map sensor in that box to the nipple on the throttle body. is that what i was suppose to do for the map sensor. i mean everything i read about the swap is that you mount to map sensor on the firewall. im very confused! someone help me out
5.6L V8 32V DOHC
JDM HERITAGE - US BUILT
