Help with H22 swap!!!
    my swap came with a little 2" x 4" box thing with 5 wires coming from it... on my car it is located towards the headlight side of the shock tower...does anyone know what this is??? also the pins arent the same so i will need to cut and splice them together correct???
    thanks for (+) input!
    some pics might help, but if its metal, i would guess it might be the injector resistor box... especially if its on the drivers side... goodluck...
      youre using your stock wiring harnesses and whatnot, so you should have to worry about the new resistor box. though, if its from an h22, it should have a matching connector... but leave your stock one in and ull be fine...
        I would just snatched the one off the f22 and just leave it
          Either that or it's an Igniter ?? Pic's Please.
          But as CP[Mike] suggested, when you do the H22A swap you use the Original F22 Engine Wiring Harness with Modifications, so there shouldn't be any need for swapping it out.
          In case you haven't already got it get "The Ultimate Swap Guide".
