OK I read the DIY on how to convert automatic to manual, i got all the parts required, so i began to do the conversion, everything was going according to plan, its untill I began to install motor mounts that I ran into a problem. As I began to finish my instalation, i realized that the tranmissions sits too close to the crossmember that has the rack and pinion mounted to it, and it dos not let me mount the engine properly, therefore not allowing me to install the rear motor mount. i tried shifting the motor in different position, but still it wont sit properly. is there anything i missed that i should know?
P.S. im using the manual trans mounts
. I actually ran this setup for about two years. All my mounts wore out and distorted themselves, and I started breaking axles about once a week. I then changed everything. New drivers mount, dx/lx rear mount/bracket, 5spd accord tranny mount and 5spd bracket welded to the rail. In the front, I'm currently using a prelude crossmember (92-96) mount and motor bracket, but thats mainly due to reducing engine movement and making room for the turbo. You should be using your stock front crossmember and dog bone mount. (Some people get confused about the prelude front mount/crossmember, so I try to clarify)
