h22 fluids? hood?
    h22 fluids? hood?
    i've searched and all i got was f22 types and other BS...so what is the best oil to run in stock h22? which manual tranny fluid? also, the PS hose isn't letting the hood clear, therefore, will it be safe and dependable to cut out some of the bottom of my carbon fiber hood to make it clear?
    thanks for (+) input!
    First of all the fluids for H22A have been covered you need to search harder. Manual tranny fluid i use honda MTF. You can use 10w30 also for it. Your PS hose should clear a lil better if you hit the hose down not too hard with a rubber mallet (thats what i did to mine) Dont hit too hard or else you might snap the outlet or you can find someone to re route the hose for you. I have a custom chip in my hood from my PS line hitting it.
      isn't it 5w-30 for all honda motors........10 30 is too thin is what i was told by Honda......
      93 Accord- SOLD
      94 Civic- F22a1 Swap, current DD
        They are the same viscosity when at operating temp.
        2003 Maxima SE Titanium Edition
        1993 Suzuki GSX1100F 136bhp
          I'm lost... how is 10w thinner than than 5w?
          Oil leak?What oil leak? That's just sweat from all that horsepower!
          Applied knowledge is power!
          NITROUS FOR YOUR BODY
          BIRTHDAYS ARE JUST AROUND THE CORNER
          registration is free
            http://cb7tuner.com/vbb/showthread.php?t=2861
            it says 10w-40 for tranny? not sure if it applies to h22
            Frost White CB7 Crew #26
              Well, that's allegedly from a Haynes manual.
              http://media.honda.co.uk/car/owner/m...al/400/8-2.pdf is the factory manual pages for trans oil. 10w-30 or 40 SF, circa 1991 oil, which you won't find, nor does Honda use or recommend any more.
              MTF has the proper amount of phosphorus for proper syncro protection.
                if you want some better and you got some extra money, then just go with royal purple. some very good stuff
                  I used royal purple...didnt really feel any difference.
