Universal O2 Sensor Connection?
    When we did the H22 swap the O2 sensor plug was universal, and I think my boy hooked it up wrong. On the new O2 sensor wires are 2 white, 1 black, and 1 grey. On the engine harness there is 1 green, 1 grey, 1 orange, and 1 yellow. Could someone please help me hook these wires to the right ones, basically which ones go to which.
    In Europe Honda released the Honda Accord with a H22 motor, it was called the Honda Accord Type R .
    don't see why you're having trouble with the O2 sensor. the cb7 wire harness is completely swapped onto the H22, therefore the O2 sensor should plug right up
    5.6L V8 32V DOHC
    JDM HERITAGE - US BUILT
      Well.......
      It's just that I think we didn't know that and swapped the whole H22 harness into the car. It might be hooked up right, but I just need to check to make sure.
        is the cel on?
          Yeah the Heated O2 Sensor CEL is on so I think one of the wires must be in the wrong spot.
          Does anyone know which wires match up for the four wire o2 sensor? Even if you could just check what your car has for me plz..
            I must be the only person with the four wire connected 02 sensor
              No your not, you probaly have a LX and the prelude O2 sensor doesnt hook right up like mine. The 2 white wires on the sensor are for the O2 heater and go to the 2 black wires on the harness, the grey one (ground) goes to the green and the black one goes to the white (Signal).
                I do have an Lx with a Prelude o2 sensor. I'm gonna check to see if they match up.
                  if you used the H22 harness like u said, and you have a prelude O2 sensor, it should plug right up
                  anyways, get a cb7 Lx O2 and see what happens. i don't know if you used your cb7 or bb4 harness, but figured this will help somewhat.
                  5.6L V8 32V DOHC
                    The prelude O2 sensor has a male connector and the harness of the 4th LXs is male also. You need to modify it to a female connector for the prelude O2 sensor to plug right up. Or get a the LX O2 sensor. Im modifying my harness to a female connector today to use my prelude sensor. Ill let you know how it goes.
                      Well I connected the wires just like you said, but it is still throwing the heated o2 sensor CEL? Is there anyway you could send me a pic of your o2 connection?
                        Well I still havent figured mine out yet, I had cel code 41 and after hooking it up I now have cel 1. What cel code you are you throwing? My next plan is to test the signal of the O2 sensor to see if its even working.
