So I have my CM5 that got totaled last year and want to swap it over to CB7. What parts can use from CM5 besides the engine, transmission, shifter cables and shifter. Can I use the harness or the ECU, axles, I know I need to buy the Hasport engine mounts. Any info would be greatly appreciated.
CB7 swap with K24a4
you want to start reading up about kswaps. typically people use the 02 04 rsx engine harness like I did but I know you can use the 05ish tsx harness
as far as axles you can use 08 si axles on both sides as long as you use the rsx intermediate shaft.
idk about the length of the intermediate with k24a4 but I know I had used a tsx mt intermediate shaft because it its longer to clear the weird oil filter location on my k24z1. because I used that longer intermediate shaft I found an ilx axle is the right length with it (HO-0411)
