h23 swap power steering
    I'm sort of confused because I'm getting different answers but my question is if I could use the high pressure power steering hose from the 92-96 preludes that goes on top of the pump or if I should use the accord one and which would be easier.also does the prelude bolt right up without any problems?.thanks.
    Project EP hatch on the way
    Can anybody help me?
      yes you can use the line from a 92-96 prelude, bolts right up no problems with it at all. Make sure you change the line out with engine out otherwise it will be a little harder.
        Have you use the h23 ps pump and rack also i believe.
          Yea I'm runnin the prelude pump.I really appreciate ur input guys.
