Soon I will be purchsing a JDM H22 to swap in my 1992 Honda Accord 4dr. But before I purchase that I would like to buy some performance motor mounts. Now since the swap is a easy bolt in swap. I would just basically want to buy Stock motor mounts but I would like some a little bit stronger. So is there any company that makes performance Accord Mounts for my year?
New Motor Mounts
poly is much stiffer but they are about the same..poly lasts longer...lets just say that oem lasts like 13 years...and poly is more....
i got the two side ones here if u would like it...they are used, still good OEM....ill sell it to u cheap.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
So basically your saying you "restored" your stock used bushings by doing that? Doing so by sealing up existing cracks, etc.Originally posted by h22wagon
i filled mine with 3m window seal. its in a calk type tube, you can get it fron advance auto or just about any auto parts stores. i havent got the h22 running yet becouse im waiting for a intake mannifold gasket but when its all done i will let you know if this helps at all
Never heard of that approach, wonder how long that will last if I understood you right.
I'd be interested in finding out how much Energy Suspension or Prothane would charge to make/supply motor mount bushings for 4th gen Accords. Prolly wouldn't be hard for them to make them.
well i have the motor running and the mounts feel more solid but not harsh. i havent launched the car yet so i dont know how that will feel yet(i want to break in the motor becouse its been sitting around for a while). i have the energey suspention poly bushing in the front and i think the rear is the same so you can use one in the back too. but im not %100 sure.
