high idel
    high idel
    i got the h22a to run now it sits right on 2,000 rpms all vacs. lines r on it if u push back on the butter fly the rpms drop the thra cable is lose to anyone know what to ajust thanks
    adjust the cable to spec?
    it may be too tight ......first try lowering the idle screw and then adjust the throttle cable deflection to about .5 inches.
    Retro!
    Hater
      witch screw is the idle screw the t.cable is not even on it it just hanging there
        check your distributor b/c when my mechanic swapped my f22b2 is was reving at 2000 and higher....so when i took it back he adjusted my distributor and adjust my throttle cable just a bit and now everything is perfect and i love the timing now.
        " The value of life can be measured by how many times your soul has been deeply stirred " - Soichiro Honda
