H22 swap wiring ?
    H22 swap wiring ?
    so i took some time off of my swap, ive got a 91 accord, 94 usdm h22 wrapped with the stock accord harness. i was gunna originaly run the usdm distributor with an msd iginiton. when i had everything hooked up with the msd, that was when i was throwing all of the codes. i just ordered in an internal coil prelude distributor, before i swaped that one on i had a handful of cels including crank position, and code 15 which is ignition output signal. i just put the new distributor on and ive got the 15 code still there, im sure its a wiring issue, anyone have an idea of were to start to test the wiring.
    New cb, new start
    small update, i just tried testing some wires, the black yellow has power, i know thats good, but when you check the yellow green there is a click when it is grounded? i dont have a wiring diagram anywhere around me but isnt that the trigger for the coil?
    New cb, new start
      You tried clearing the code, right? Does the car start/run?
      EDIT: try downloading this (92-96 Prelude service manual):
      http://downloads.hondatech.info/Auto...e%20Manual.zip
      and look at page 11-80. It gives you a good flow chart to check things. I already had it, I had to look up where to get it again.
      Good luck!
      1992 Prelude S w/swapped H22A
        yup, nothing, no spark, injectors are firing
        New cb, new start
          just swapped out the igniter and still nothing, looks like this is gunna be on hold for a while, just blew a fuel line. i guess this is the kind of fun you have when cars sit.
          thanks for the link to the manual, ill give it a try, got nothing but time, wanna get it done this spring, just would be nice to get it started
          New cb, new start
            just wanted to say thanks, we have alldata at waukesha tech, but im on winter break, this is exactly what i needed flow charts ftw
            New cb, new start
              No problem. I'm in the middle of my own swap right now, so maybe I'll end up having the same problem
              Did you check your coil?
                ohmed the coil, it was in spec, realy not sure what else it coulda been its either i messed up the wiring when i was going to run the msd ignition or my ecu is shot
                New cb, new start
                  just wanted to say thanks again, found the problem, yellow green wire has power at the distributor, and both sides of the plug for the engine harness to dash harness, and nothing at the ecu
                  New cb, new start
                    No problem! Weird that it died at the ECU, though.
                      its somewhere between the grommet in the firewall and the ecu, its all loomed, but it was a high of 7 out here today so i wasnt gunna mess with it
                      New cb, new start
