Swap Question
    Swap Question
    I think im gonna buy the H22 pretty soon. If i buy the complete swap, will it come with everything needed for the swap? Or will i still need to find parts from a junkyard?
    Are you going doing an auto--->manual swap as well?
    If your car is allready manual, you need the engine, tranny, ECU, alternator, starter, clutch/flywheel, intake/exhaust manifolds, throttle body/air intake plenum, fuel rail, injectors, sensors.
    I might be missing something else, but thats generally what you need. You use the accord halfshafts and axles.
    1993 Eagle Talon TSi AWD - The new project
    1991 Honda Accord - Point A to point B car
    2006 Kawasaki Z1000 - The toy
      It is going from auto to manual, in the description it says it comes with clutch and all shift cables.
        http://www.cb7tuner.com/vbb/showthre...=&threadid=588
        BAM i knew there was a topic somewhere about this.
        This should help alot. Good luck with your swap!!
