Quick verification question...when you rock the distributor towards the rear of the car (counterclockwise) you are advancing the ignition and retarding if you rock it towards the front of the car, correct?
distributor - advance/retard rotation
Originally posted by The G-ManI am 90% sure that is correct.
Originally posted by d112crzySo you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
Here's the story...got a customer thats having a low rpm (2300-2800rpm) knock under moderate acceleration. Told him to adjust timing at his distributor by clocking it and rotating it towards the front got rid of the knock. I'll be able to do this on the map easily i just needed verification that clockwise rotation was in fact retarding timingKnowledge is power...in EVERY sense of the word
think about how the rotor is connected directly to the cam.
looking at the dizzy from the cap side , counterclockwise (left toward the firewall) would be advancing it, clockwise toward the front of the car would be retarding.
Originally posted by MRXHere's the story...got a customer thats having a low rpm (2300-2800rpm) knock under moderate acceleration. Told him to adjust timing at his distributor by clocking it and rotating it towards the front got rid of the knock. I'll be able to do this on the map easily i just needed verification that clockwise rotation was in fact retarding timing
