Cluster problem
    Cluster problem
    just the other day i went to start my car when i noticed that nothing on my cluster was working except the battery light when it was in the on position. when it does turn over, i have no tach, speedometer(i know i need a new speed sensor for that problem), im pretty sure my temp gauge isnt working either. what does work is blinker lights, high beams, lights behind the cluster. thats it though. any help would be greatly appreciated.
    i did check all fuses, that i know of. lol
    work in progress..
    Well there is an instrument cluster fuse under the dash. If thats good I would check the connections to the gauge itself which are probably good. Next thing I would do is check the wiring of they are in spec. Every sensor has a spec if you ohm it out I dont have the list on me but the temp and so on should have a specific reading. If all those test out good then you probably just have a fubar'd cluster.
      thanks. ill have to take a look tomorrow.
      work in progress..
        the clustrer fuse that is under the dash, is it in the fuse box down by the kick plate, or the near the steering column?
        work in progress..
