can I run the 0-5 volt output from my wide band to my crome ecu?
0-5v output from wideband directly to ecu
It's a hardware mod.
If you want to get rid of the oem sensor then just take it out and plug the hole.
The only thing you have to do is disable the o2 sensor in the program that was used to tune. And if you're tuned, then it should already be disabled. Hopefully anyways.
I already have the wideband installed. I have the oem sensor hooked up to the ecu. I have two o2 sensor bungs
