Well every thing was working fine til 2 weeks ago. I notice the steering wheel is harder to turn. Check the Fluid and it was below level. Fill it up and it was back to normal for a day. Next day I check the fluid level and it was below level again. I checked for leaks and there this hose that looks wet. I replace that. It's call the return hose for power steering. It still didn't fix it. It so hard to turn a corner. Really need your help guys.
Help with lost of Power Steering fluid?
Cool, so engine off and wheels straight. I saw HONDA power steering fluid at autozone, and was confused. It says HONDA on it, but its not the OEM HONDA fluid. It's in a black bottle. I'll pick up some OEM fluid tomorrow and refill it. My power steering fluid is low, but when the car is on it raises.
There is an aftermarket brand of power-steering fluid designed for Honda systems. Bardahl is the brand-name, in a black container with yellow/green/white label on it, if they haven't changed the appearance. Some auto parts stores have it. I have been using it for years with no issues on ALL 7 of our Hondas.
There is also a brand-name "GUNK" that sells Honda specified power-steering fluid.Last edited by HondaFan81; 01-29-2006, 07:33 PM.
Originally posted by i97suprattiMy power steering fluid is low, but when the car is on it raises.
With my rack, it doesn't seem to actively leak, if you watch it it won't leak, but the whole rack looks like it sweats I need a rack rebuild, but the leak is slow and I have been putting it off.
NOT is normal operating temperature. F22-GURU is advising to warm up the car first than turn it off to get the proper level.
Originally posted by F22-GURUEngine at NOT
Engine Off
Steering Wheel Straight
Vehicle on Level Surface.
USE ONLY HONDA PS FLUID.
Bleed Steering by turning wheels from lock to lock.
Check for Internal PS Rack Leaks as well. Remove the PS Rack Boots, if there is PS Fluid in the Boots then you hav an internal leak.'92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
EX Lip & Alpine OEM single CD Player. No more useless pocket!
TIP: For those who have to replace a PS Pump, Hose or PS Rack. After refilling the reservoir and starting the car, do not leave the engine idling while topping up. It only takes a matter of seconds for the PS Pump to run dry and fuck the internals. (That's what the whirring sound is).
This is the procedure I use when replacing PS Parts.
1. Fill Reservoir with Specified PS Fluid.
2. Start Engine and observe the Fluid level in reservoir.
3. When the level drops below LOW mark, switch engine off.
4. Top up Reservoir to Correct Level.
5. Repeat Step 2 - 4 until correct level is achieved.
6. Turn steering from Lock to Lock to bleed out air in system.
7. Let engine idle until PS Fluid settles. (PS Fluid may aerate)
8. Switch off and Top Up level if necessary.
