Alright guys heres the deal, last night i took my h22 to go get tuned everything was fine and dandy on the dyno and the tuning went fine. well when i left the shop i drove a little ways and decided to feel the power i had just made well that didnt happen. Whenever i give the motor full throttle it skipps and jumps very violently and is very irratic. It drive perfectly normal if its is being daily driven but if you give it any gas it goes crazy. Every time it acts weird i turn the car off and then back on again and the problem is fixed untill i try to floor it again. Any ideas as to what it might be. the chipped ecu doesnt read EGR either if that helps
H22 skipping and jumping violently HELP!!!
Anybody????!!!!????!!!! i need to fix this problem ASAP its making me think its some sort of sensor because it only does this problem AFTER i floor it and it stays untill i restart the car then drive fine after the restart.....making me think it is some sort of sensor that is being reset untill i floor it again.
If it was working ok when you went in to the shop the first time, but wasn't when you left, sounds like shop screwed it up?
I don't know, I think I'd ask them for some of that money back, cause if they burned the first ECU, and then charged you for another one, that's messed up.1992 Prelude S w/swapped H22A
