i am not 100% sure but i think this has to do with my transmission. it only happens ocassionally, but sometimes when i start the car and go to pull out, it lack all power for a couple seconds. then it picks back up and is fine. very annoying though. it is an automatic and 3 months ago when my TCU went out i replaced it with one from an LX but my car is an EX. this problem only started like a month ago. also replaced my o2 sensor twice in the past 3 months, so i don't know if that has anything to do with it. any advice?
Transmission vs. engine problem
What does your tranny fluid look like? When was the last time it was flushed/replaced?
Honestly, it sounds like your AT starts to fully engage shortly after you're moving.No more cb7, 7 years of ownership and 196K on the ticker before she was sold
Current beast: 98 ej8 on 7psi with a 15g turbo and other goodies!
NREMT-B | 300D and some glass
tranny problems..
My '93 10th Anniversary is having a tranny problem also. In D4, the car starts off in 3rd gear judging by the rpm and speed, then shifts to 4th after a while. It doesn't downshift to any lower gear than 3rd when I slow down.
Right now I'm having to shift the car myself, by putting it in D1, then to D2, D3, D4. But here's the thing, when I shift it to D2, it shifts to 3rd, and once I hit 40 hit downsfts to 2nd.
Are these symptoms of a fried TCM? I'm having a friend check out the board to see if it's done with.
Also...is it bad for my tranny to be driving like this?
