Srtipped Thread on Head
    I was doing my lower tube seals and I screwed up.
    I stripped two threads in the head:
    I have no excuses, I messed up plain and simple.
    Can this be re-threaded or should I just swap my other Accord Head on instead?
    (It's a 91ex head, I have a 92 lx, that's no problem swapping correct?)
    (On a side note I was planning on doing some work to the head: cam re-grind, mill the head and p&p.... I was thinking more like 3 months from now...)
    Any advice would be appreciated!
    get 2 new bolts, then re-tap the hole. that works most of the time.
    if that doesn't work, try hexi coil. later.
    Avoiding dirt at all costs
      Okay... thanks. Starting to calm down.
      I will give that a shot!
        I believe it's Helicoil, if it comes down to that. You might be able to just use a thread cutter and chase the threads. It might clean them up enough for you to get it down.
        1992 Prelude S w/swapped H22A
          Thanks for the help
          I ended up re-tapping the threads and that saved the day.
            Originally posted by kingdave9
            Thanks for the help
