where do i put the temp sensor sending unit? I'm not sure if thats what it is called, but it is the metal piece that goes in the water, and reads the temp.
I don't really want to disconnect the factory one, because i want to compare the two readings, and because it throws a check engine light when discconected.
HELP!
thanks!
__________________
HELP!
thanks!
__________________
