idle issue
    idle issue
    alright. i start up the car, but shut if off quick because i cant stop the raising rpms. it will start at 2,500 rpm and rise to past 3k!!! wtf?
    so i take the vaccum line off the tb (map sensor) and it idles around 2k. but the car is rough.
    what could be the issue?
    miss my turbo cb7
    have you read the thread about fixing your idle yet, and tried all those methods?
      If all the troubleshooting doesnt help, and you think you have a vacuum leak try this...
      try getting some throttle body cleaner and slowly spray the areas where the gaskets are on the intake manifold (manifold to head area / IAB plate area / TB to plenum area, etc). If you have a leak the car will bog a little when you spray that point.
      Formerly 91AccordExR33
      11.68 @ 127mph
      417whp/375wtq
      Sold: 8/2016
        Sounds like a vacuum leak. Broken intake manifold gaskets do that. Thats one thing to check
          no vaccum leaks
          miss my turbo cb7
            HG leak?
              Originally posted by oozingmachismo2
              HG leak?
              new headgasket
              miss my turbo cb7
                Ok so you have no vacuum leaks, how you know there arent any broken pieces of the intake mani gasket? Have you smoke checked it?
                  all new gaskets.
                  its acting weird now. i give it full throttle in first and it just moves slowly. i was comming down a small hill on full throttle and its barely hitting 2k rpm. i guess i needs to get tunned.
                  miss my turbo cb7
                    Have you checked to make sure nothing is lodging the throttle plate open?
                      yea it opens up normaly. on stand still i could rev it till i hear the bov (which is 5k)
                      miss my turbo cb7
                        Oh your turboed. What kind of engine management you using? Whats your setup? I think this will be the extend of internet diagnosis before I would actually need to get my hands on it
                          chipped p06 by mrx
                          stock fpr
                          stock engine
                          dsm 14b
                          currently at 6psi
                          2.5" intercooler piping
                          ecu is set to 12psi
                          current fuel pressure is 35 at idle, 42 at wot
                          miss my turbo cb7
                            If you ever get this thing squared away it will be one bad muthafucka. yes indeed
                              Put your stock ECU in it and see how it idles
