So The clutch will only engage when the pedal is almost out completly. the slave cyllinder and the master cyllinder are only about 2-3 years old, the fluid is alright and it doesn't have abs. Dose anyone have any suggestions or ideas what this may be?
clutch only engaging when pedal almost out
Originally posted by yeamans17Adjust the pedal, get under there with a 12 or 14mm wrench to loosen the nut and adjust it til it feels better.
Originally posted by orangerYour clutch is worn out. It may not be slipping yet, but its at the end of it's life and the pressure plate is extended to its maximum, which is why it is not engaging like you expect. Replacement of the clutch will fix this problem.
Anyone else agree with this statement?
