is there a DIY for seafoam??? my car smokes bad when i hit 4k plus the ca has 230xxx miles on her.
seafoam
yup!Originally posted by C91BLX7If there isn't much wrong, don't do it,
It sure as hell won't fix oil burning, for that you need new seals and or rings
seafoam will only make the oil burning WORST ( why..because its desolving the deposits thats HELPING it not smoke that much )
you only use seafoam to clean the fuel lines...intake manifold..and etc...when you have a accelleration issue ( not related to ignition or fuel but rather mechanical due from dirty or clogged EGR ports or gunked up ringlands )
seafoam is good shit...but if you're smoking....its either valve seals..or piston rings are done! ( rebuild or swap time )Last edited by SN2BH22CB7; 05-28-2008, 10:38 AM.92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
