clicking noise while turning right
    my 90 accord lx makes an annoying clicking noise wenever i accelerate on a right turn. it stopped for a while, but now its back. does ne1 have ne idea wuts causing this and ne way to fix it?
    noise
    frum earlier tonite, it sounded more like a card in a bike wheel
      pry bar helps to pry the axle out the tranny, you'll need a new hub nut & c-clip, 32 mm socket, anti-seize the threaded end of the axle, chisel & hammer to lock hub nut, ball-joint separator, prolly new cotter pins for tie rod & lower ball jt unless u didn't mess 'em up. a torque wrench would be nice if you want to properly torque the shit or just do it to whatever you feel like.
        Well said Fizz... An excellent description.
        Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
          i was just being more detailed & describing the proper method. I personally like to torque things down to spec if it's rather important because there is such thing as over-torquing some parts if you have no clue what it's set at & shear it off. Plus, if you don't tighten it down correctly, it may vibrate itself off. Rather be safe then sorry.
          example...overtorquing ur lug nuts can warp ur rotors....some bitches at a tire shop did on our sable....again just depends on what part we talkin about
            Over tighening lug nuts can warp rotors? uh oh... No wonder my rotors are warped, i just posted a thread about an hour or 2 about that. Shit that sucks, wish i would have known that earlier. lol
              I guess i am going to have to go get them machined tomorrow, lol.
