Ok so I bought a 92 lx auto. I fix all the bug in it that the previous owner failed to warm me of.
This is a problem that just pops up from time to time. It only does it when the car is warm or it is hot outside. It is trowing codes 1,2,3,7,8,14 from the tcu(D4 light blinks). And when this happens if you un hook the battery for 20 seconds it will erase everything and start right up no problems.
Here is a post on what the trouble codes mean.
http://www.cb7tuner.com/vbb/showthre...ight=TCU+codes
According to it they all are solenoid codes beside the TPS code.
If I replace those solenoids on the transmission should it fix it or should I check for voltage from the TCU.
