Okay I messed up the TDC or whatever in relation to the cam and and crank. I'm hitting a valve or something, the engine is not rotating when i was manually cranking it.
So i probably need to remove the crank pulley. But how do you do this w/o an impact? I know I already have to remove the PS and the Alt. already...ugh i'm getting PISSED this was NOT supposed to happen, I didn't even touch the crank when I took the head off, and I set the cam to TDC for #1 and now its hitting valves. FUCK!
not to mention, one of the lower bolts holding the plastic shroud is just spinning, I can't even get the damn cover off. So idk i need help.
