TAS quality?
    TAS quality?
    TASauto.com has there lower control arm bushings inner and outer for $14.95 each, then they also sale OEM Honda lower control arm inner bushings for $19.95 and the outer for $15.50
    The same thing go's for their lower control arm ball joints. Theres are $12.95 and the OEM Honda ones on their web site are $24.95.
    I could save a lot of money by using theres but I want the best foir the J swap. Would thiers be adequate or no.
    Also their TASPRO Front upper control arm set which has the polyurethane bushings, does anyone know what upper ball joint they use? Its adjustable, but is it ingals or even worth getting?
    Nevermind about the lower control arm bushings. I will go with their complete polyurethane set. It includes those bushings right?
    The questions above still stand for the upper control arm and the ball joints.
    Thansk alot
    Derek
      For suspension parts i'd go oem or better.
