i was removing some of my stock intake pipping that is right by the headlight and goes into the fender and i removed like a little sensor.. do i need this plugged in still. in plugs into a little black box there on the fender
intake sensor
intake sensor
Backyard Customs
Building Fund: $0Originally posted by xprojectcb7xwhy would you think people at auto zone would know what they were talking about?
http://www.cb7tuner.com/vbb/showthre...="0" alt="" /> CLICK IT!!
Tags: None
More than likely not a sensor, but a solenoid based on your description. Not needed if what you are doing is installing an aftermarket intake system. Keep it if your staying stock obviously.Originally posted by byc_cb7 View Posti was removing some of my stock intake pipping that is right by the headlight and goes into the fender and i removed like a little sensor.. do i need this plugged in still. in plugs into a little black box there on the fender
a useless part of the stock intake tubing... pitch it
Didn't your girlfriend say the same thing about you Mike?Originally posted by cp[mike] View Posta useless part of the stock intake tubing... pitch it
ok thats what i was thinkin should i jus put a plug over where it was connected
Backyard Customs
