grinding while turning
    yo what up all ive been having this problem ever since i took off my p/s it grinds while turning the wheel but only on hot days its pretty weird so i dont know if it may be something else ive added alot of p/s fluid over time but the grinding continues any suggestions would be appreciated
    member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
    If it grinds then it probably does it all the time it is just louder when it is hot. Try getting the car off the ground and have someone turn the wheel both ways while you listen to the steering rack for noises. Also check all your ball joints and bushings.
    -1991 Honda Accord LX H22a-
      Probably the tie rod end
      South Texas M_thaf_cka, that's where I stay!
      Check out my Frost White CB
      http://www.cb7tuner.com/vbb/showthre...ight=SpdJnky93
        just replaced both tie rod ends and ball joints but i have a spare set ill put those in and see and also try puting up on a lift at work
