Hey guys i was debating on H23 swap and boost or rebuild my F22A6 and boost. However i cant seem to find anyplace that will do a rebuild quote at all for me.. help me out guys
Engine rebuilds?
Engine rebuilds?
R.I.P. Landon Hilburn 06-27-08
Soon to enter the family.
CG Coupe!
92 Accord EX Sedan (Newest project)
Members ride thread 92 EX Sedan
Members ride thread old 91 LX CoupeTags: None
I say swap it to an H23 not as much fun as an H22 buts its an upgrade, but if you want a lot of headaches and power go turbo.Last edited by NorcoAccord; 06-29-2008, 02:50 AM.
Originally posted by C91BLX7 View PostDo it your self. Its not that hard.R.I.P. Landon Hilburn 06-27-08
CG Coupe!
well just a cyl. head rebuild cost me about 500 and this was doing it myself.
300 for a machine shop to rebuild the head w/ new seals and valve job, pressure test and resurface. And then the rest for gaskets and stuff (HG - 75, IM gasket- 57 bisimoto one, EX gasket - 15, coolant-10, o ring seals-10)
Originally posted by Losiracer2 View Postwell just a cyl. head rebuild cost me about 500 and this was doing it myself.
300 for a machine shop to rebuild the head w/ new seals and valve job, pressure test and resurface. And then the rest for gaskets and stuff (HG - 75, IM gasket- 57 bisimoto one, EX gasket - 15, coolant-10, o ring seals-10)R.I.P. Landon Hilburn 06-27-08
CG Coupe!
Originally posted by blackedout View Postwell what is recommended for the rebuild?
Originally posted by Losiracer2 View Postidk, but i think new piston rings...haha i have no idea. But another shop quoted me like 900 for a complete rebuild but using aftermarket parts though, so idk about that one. I would use all Honda stuff just for reliability
I'll be moving to phoenix in octoberR.I.P. Landon Hilburn 06-27-08
CG Coupe!
Originally posted by Losiracer2 View Postuh i think tri tech motorsports or something like that. I found that place in the vendor sect. of www.azht.netR.I.P. Landon Hilburn 06-27-08
CG Coupe!
300 for a machine shop to rebuild the head w/ new seals and valve job, pressure test and resurface. And then the rest for gaskets and stuff (HG - 75, IM gasket- 57 bisimoto one, EX gasket - 15, coolant-10, o ring seals-10)**Blk Housed Slut Crew Member #1**
Originally posted by F20A CB7 View Post300 for new seals and valve job? What about the springs and retainers and all that, did u use stock new pieces or same shit u had on b4.
All they did was put new valve stem seals in, since, I figured it'd be good to do it now rather then having to take it all apart again in case they fail.
