O2 Question
    O2 Question
    Would I be able to wire the O2 directly to my ecu? My O2 harness got caught around the CV joint and pulled the green/white wire out of the harness. Regardless, I do not want to hunt it down. Can I just create a new harness and swap the pins at the ECU?
    D22, D14, A6, A25
    NWTuner.com
    Yes you can, All the wires goes to the ecu anyway. So just get the right pin out and make your own harness if you want.
