i was cruising at about 65-70mph and all of a sudden the RPM's go to 0. the motor was still running, but i had no throttle feel or anything. i pulled over immediately and shut the car off. i checked everything i could. oil level was good and clean, battery connections good, no fluids leaking or anything, no broken belts. so after about 15-20 minutes i gave it a try starting it, it cranks but no start (hoping it would be just a main relay issue). no luck with that, so i called AAA for a tow and now im here at home.
i did install a pt6 ecu yesterday, but it ran fine last night (actually it ran great) and all day today up until the motor broke down. could it just be a coincidence, or should i swap the pt3 back in?
as far as i know, there were no other abnormal signs of anything going out on me.
